TPS 2002 Camry v6 Help
#11
I'm checking my tp% for the first time since I fixed it. I just noticed something.
when the car is off or only in the on position my tp% is at 17.6 ( probably moved some from vibration and driving still within the range though)
thats what you are doing now. But when i watch my tp% with the car running it will display a different number so after my car warmed up it dropped down to 14%
so that probably explains the other range it gives further down in the instructions of 10-14%. And when i turn the car back off and just to on position the tp% goes back to 17.6%
i just wanted to give you a heads up that when the car is running it will display a totally
different percent than you set it at initially but thats okay.
