Water temp gauge and sending unit, aftermarket gauges
Old Sep 21, 2010 | 05:24 PM
RickSRQ's Avatar
Default Water temp gauge and sending unit, aftermarket gauges
'98 5SFE
Has anyone ever had an experience with a faulty temp gauge sending unit? Are there "cheap" brands that might return a less than accurate reading?
I have an issue with my gauge reading about 3/4 when everything, and I mean everything, is new. The car had a blown motor and was replaced with a rebuilt 5SFE, along with rad, water pump, thermostat, etc..., and all sending units and sensors.
The wire that is plugged into the sending unit had a tear in the insulation, I taped it up, but I was wondering if it might have a resistance issue.
Also, has anyone ever installed an aftermarket electric water temp gauge in the stock sending unit location? What brand? Will I need an adaptor?
We put a laser temp gun to the bottom of the rad when it was at temp, and it read 192, but I don't trust it, plus I figure the outside of the rad tank could be 20 degrees cooler than the water inside. I would really like to put an aftermarket gauge in it to be sure.
TIA
Greasekind14
Jun 10, 2016 12:35 PM
elpearl
Oct 9, 2011 12:38 PM
vin888
Mar 6, 2008 08:39 PM
saxman
Oct 3, 2007 11:06 PM
tg305
Nov 5, 2006 01:24 PM
