Where does OBD2 go
Old Oct 20, 2019 | 02:25 AM
1995camry's Avatar
Default Where does OBD2 go
I have a 1995 Camry 5s-fe with a 96 motor, computer, and engine harness. Car runs with a check engine light. The harnesses for the cabin are very similar for the 95 and 96. OBD2 is 4 wires on the drivers side on the 96. Does anyone know where these wires go to? I was trying to figure it out so I could wire them directly in to check my engine light. I grabbed the obd2 off a 96 from the junkyard. Anyone have any ideas, Im currently stuck.
Old Oct 20, 2019 | 01:00 PM
One problem may be the 1995 does not have OBDII but the 1996 does.
Old Oct 21, 2019 | 12:48 AM
1995camry's Avatar
I realize, I swapped over everything in the engine bay. Just curious if anyone knows where the obd2 wires go on a 96 wiring harness. I could go about pulling the dash and installing the 96 wiring harness. I was hoping to avoid this
Old Oct 21, 2019 | 01:20 PM
Blue/white wire goes to computer.
Brown is ground.
Black/yellow goes to EFI relay. WIre is powered by 12v when relay is closed..
Old Oct 23, 2019 | 08:12 PM
1995camry's Avatar
I'll see if I have any luck. I have 2 white wires, one with a black line through it. Then a black and a brown wire. I assume both white wires goes to the computer, brown to ground and black to the EFI relay.
Old Oct 23, 2019 | 08:21 PM
1995camry's Avatar
Worst case scenario I would have to source a 1996 wiring harness, or just spend an hour or two removing one from a junk car
Old Oct 23, 2019 | 08:50 PM
The 1995 has the wire colors you describe.
Solid black is ODB fuse.
White/black is ground. Appears to be Chassis Ground.
White goes to computer.
Brown goes to ground. This wire connects to the shielding of the white wire. Appears to be Shielding Ground.
1995camry
Oct 10, 2019 02:09 AM
hink85
Jan 23, 2013 06:00 AM
ps_outrage
Jun 24, 2010 08:18 PM
plee
Sep 26, 2009 08:25 PM
