Swapping 1995 Camry to OBDll with 96 motor
Hey Guys, over the past few weeks, in my free time after work I swapped a 1995 Toyota Camry LE with a 1996 Toyota Camry LE Motor (5s-fe). Same motor but a bunch of different goodies on the 96, crank angle sensor, new canisters. What I took over was almost everything different in the engine bay, 96 ecm, motor wiring harness, etc. The fuel pump worked fine before the swap, but it seems to not get any fuel now, will power up when you spray starter fluid into it. The only thing unplugged is a plug under the dash that sits right by the airbag and two other connectors. The obd2 connector isn't hooked up but I didn't think it was necessary currently also I don't have one on me at the moment. Is this wire to the OBDll connector or something else. I'm mainly looking for someone who has turned a 3rd gen Camry 4 cylinder into obd2
