Wiring a new radio
Your photo has two harness plugs so assume the stereo has a built-in amp.
The links below may provide you with what you need. Use the diagram having two plugs.
https://www.tehnomagazin.com/Auto-ra...-Connector.htm
https://www.installdr.com/harnesses/toyota-wiring.asp
If you don't see the wiring diagram at installdr download the pdf file as noted in the directions at the site.
Toyota uses different wiring colors for 12V power and not the usual red colored wires.
Toyota also has a connection to activate the power antenna if the car has one.
