1995 Camry XLE 3.0l v6 check engine. Loss of accel power
Old Jan 21, 2016 | 05:53 AM
OrphanUprising's Avatar
Default 1995 Camry XLE 3.0l v6 check engine. Loss of accel power
Hey I just bought this Camry about a month and a half ago and it runs spectacularly. But recently (within the past couple weeks) I've noticed a bit of loss of accelerating power and the check engine light came on. Checked my plugs and they're not wonderful but they're not bad enough to cause such a sudden loss of power. And being a 95 it's not OBDII and I don't know anyone with a code reader that will work on it. I feel like it sounds a little different now too, not exactly a knocking, but a bit of fast clicking (not super loud, but noticeable to me). Anyway, any ideas on what preventative maintenance I can do to restore it's acceleration and keep it tip top shape? (Post was longer than intended, my apologies). Any help would be greatly appreciated.
Old Jan 21, 2016 | 07:35 PM
The V6 is partly compliant with ODBII. Try using a code reader.
Old Jan 28, 2016 | 03:14 AM
coldburn92's Avatar
Work on getting those codes first.
Old Mar 30, 2017 | 03:41 PM
Jeff Toulouse's Avatar
I had the same problem. After you get your ODB code... you might want to look at 2 things. Speed sensor (probably needs replacing) and (I had too) change a fuel injector. Give that a try. Let me know if that helps.
tinkermt
Feb 14, 2023 11:54 AM
evbenji
Aug 26, 2013 09:32 PM
emma85123
Apr 26, 2013 01:47 AM
BondJamesBond
Sep 15, 2009 06:02 PM
89camry
May 1, 2006 03:10 PM
