1998 Camry timing belt
Old May 18, 2007 | 12:53 AM
vin888's Avatar
Default 1998 Camry timing belt
is the timing belt of a 98 camry LE 4cylinder is rubber or chain?
and how many miles should it be replaced?
Old May 18, 2007 | 10:26 AM
nodrogkam's Avatar
Default RE: 1998 Camry timing belt
should bea belt not a chain, and it needs to be replaced every 90,000 miles
nodrogkam's Avatar
http://smg.toyotapartsandservice.com/owners.php
refer to that website.
Old May 18, 2007 | 10:40 PM
toyoboy's Avatar
you may want to think about also replacing the water pump, timing belt bearing and tensioner, cam and crank seal, oil pump seal and oring. if you have not done so...oh and drive belts.
iamxero
Oct 30, 2013 07:23 PM
oldad
Jan 7, 2012 07:28 PM
beckepg
Jan 15, 2007 01:41 AM
Steve12
Jun 9, 2006 02:05 AM
lesaroka
Sep 12, 2005 10:58 PM
