2002 Camry 4cyl No 3rd Harsh Reverse
Old Nov 19, 2021 | 03:45 AM
ty330i's Avatar
Default 2002 Camry 4cyl No 3rd Harsh Reverse
Hey guys! I traded my jeep for a 2002 Camry 2.4 4 Cyl 4 speed. It was driving fine then I lost 3rd and have harsh reverse. I topped off the fluid and no fix. The fluid is still pink but slightly brown…. When it tries 3rd it goes to a low rpm and feels like it’s in neutral. I think it’s either low or over filled on fluid or shift solenoids are toast. Thoughts? What are common failures on these transmissions?
Old Nov 19, 2021 | 11:18 AM
Change the trans oil filter and fluid. Make sure to use the correct fluid.
Scan with an OBDII tool having Toyota codes to check for trans codes.
There is a sticker on the side of the drivers door which will have the trans model. It might be a U241E.
See private message.
Old Nov 19, 2021 | 04:53 PM
ty330i's Avatar
There is no codes BUT I do not see a TCM module in my scan tool. I see 4 modules unless the PCM is the TCM.
Old Nov 19, 2021 | 06:43 PM
ty330i's Avatar
I will re inspect fluid level and see where its at. I suspecting a shift solenoid and not a clutch. Ill take it for a spin again. I was reading a low battery can cause issues?
GrantofBellevue
May 17, 2012 09:29 PM
umdaman
Aug 23, 2011 09:46 AM
ericak95
Oct 9, 2009 02:01 PM
TDS535
May 9, 2009 04:43 PM
cardman
Nov 17, 2008 10:56 PM
