2003 Camry Transmission Issue
Hello all!
I've been noticing in mornings when starting the car and putting the shifter in Drive, it doesn't move when accelerating, it takes a couple of seconds to catch up, it doesn't happen when putting the shifter in Reverse. Once the car is warm enough it operates normally, ATF level looks normal , it happens when it's been sitting for hours and I decide to use it. Anything I should look into besides checking the ATF?
