2007 Camry not starting
Old Dec 26, 2022 | 11:25 AM
Stephen1953's Avatar
Default 2007 Camry not starting
I went out to start my 2007 Camry hybrid after sitting over night in the subzero temps outside and it wouldn't fire up. When I pushed the button, everything came on on the dash like normal but then just died. Tried a couple of times and the same result. I know this car has two batteries. One being the hybrid battery which is less than a year old and a typical 12volt battery. Would it be ok to try and jumpstart the car from the 12volt battery.
Old Dec 26, 2022 | 01:50 PM
Yes but before doing so download the owners manual at the site below and follow its guidelines for jumping the 12v battery plus see the link for Earnhard Toyota.
https://www.toyota.com/owners/resour...als.camry.2007
https://www.earnhardttoyota.com/blog...-toyota-hybrid
Old Dec 28, 2022 | 01:28 AM
EricJohn's Avatar
Cold temperatures could affect the chemical process inside the battery and reduce its ability to hold a charge. And yes your car still has a regular internal cumbustion engine that runs on 12 volts. There should be a red positive cap under your hood, hook the red to that then the black (ground cable) to a good ground.
dieuma30
Oct 2, 2022 11:10 AM
John Koffy
Jul 12, 2022 09:20 AM
Lightyr
Jul 8, 2022 01:46 PM
gaetan8888
Jan 28, 2020 04:49 PM
Eriks2009THC
Oct 21, 2011 08:06 PM
