93 camry engine removal
Old May 15, 2012 | 09:57 PM
Iflyrc's Avatar
Default 93 camry engine removal
Ready to pull engine except rear motor mount. How do you get to the nut on top of the mount? Or should I remove the nuts from the frame (undercarriage)?
Old May 15, 2012 | 10:28 PM
Remove mount from trans, not chassis. For an auto trans should be 4 bolts attaching the mount to trans housing.
Old May 16, 2012 | 07:36 AM
Iflyrc's Avatar
Thanks Joey,
But the mount in question is the motor mount under the intake. BTW, it's a 2.2 engine.
Old May 16, 2012 | 08:39 AM
Remove the 3 nuts that connect the mount to the chassis.
Old Oct 19, 2015 | 05:56 AM
johnlawrence's Avatar
Eliminate mount from trans, not frame. For an automatic trans should be 4 screws linking the attach to trans estate
blandingcamry
Nov 29, 2021 05:50 PM
baz
Jul 5, 2011 03:19 AM
Camcam
Feb 13, 2008 06:09 AM
cali_g
Feb 8, 2007 05:30 PM
Camcam
May 16, 2005 10:09 PM
