95 camary
Old May 8, 2012 | 08:48 PM
cwaite2's Avatar
Default 95 camary
ive got a 95 camary with a weird vibration/drone feeling around 45 to 60.ive had the tires balanced but ptoblem still was there.its real noticeable at 55.now i notice that it seems to have occured after the distributor was replaced.<not sure if its related or what?i was thinking about replacing the wires and plugs.not really sure but to me it doesnt seem as peppy as it once was????
Old May 9, 2012 | 09:37 AM
Is the vibration still present if you let off the gas? How about if you apply full throttle?
Any shaking in the steering wheel or break pedal vibration when braking?
Have you examined the tires and rims for damage, uneven tread wear, etc.
Old May 9, 2012 | 07:09 PM
cwaite2's Avatar
Default vibration
ive checked the tirs and wheels ok.it seems to disapate when i let off the accelerator?i was thinking i may have the distibutor advanced to much?no vibration in the pedal or floor.a little in the steering wheel
Old May 9, 2012 | 10:03 PM
full house's Avatar
probably it's the distributor seem you have it to much... try to check that out and adjust it.
Old May 11, 2012 | 07:52 PM
cwaite2's Avatar
Default adjust distributor
how to adjust distributor...may have it to far advanced????
Old Oct 19, 2015 | 05:57 AM
johnlawrence's Avatar
Have you analyzed the wheels for any irregular shake or if they are damaged, irregular stand wear, etc
mofo97
May 25, 2022 11:48 PM
mrkidd
Apr 15, 2009 10:37 AM
jetranger_2000
Jun 6, 2008 09:13 AM
StoreKeeper
Aug 19, 2007 01:02 PM
Sr3Jr8
May 22, 2007 05:47 AM
