engine removal balance
Old Jun 10, 2011 | 07:54 AM
baz's Avatar
baz
Default engine removal balance
Removing 3VZ tomorrow with transmission 96 vienta. The hook points are off centred over the engine. Is that to centre the weight when removing the engine only or is it okay to use the same points when removing engine and box as one unit or should I attach a third point to the gearbox.
The car is being scrapped so I cut off the axles (quicker and allows me to move it). Do I need to remove the axles to seperate the auto transmission after I pull it out?
Old Jun 10, 2011 | 12:37 PM
Don't know.
It is typical (and much easier) to keep the trans and engine together until out, both are lifted at the engine. If the lift points are set right the trans will balance the weight of the block. You can try lifting the unit from the hook points and determine what happens.
You don't need to remove the axle to separate the trans.
Old Jun 11, 2011 | 06:37 AM
baz's Avatar
baz
Ta, the lift brackets were good and I had a helper to guide the transmission side up so as to not damage anything.
Old Jun 11, 2011 | 08:55 AM
Great!
Old Jul 5, 2011 | 03:19 AM
sabrina's Avatar
I agree that you don't need to remove the axle to separate the trans.
erod
9
Aug 7, 2014 12:41 AM
jtmann
Dec 10, 2011 08:39 PM
1autodr
Mar 29, 2009 08:13 AM
70rrclone
Mar 20, 2009 03:38 PM
