94 Camry 2.2L crank no spark
Old Jan 14, 2021 | 04:00 PM
Auzzie's Avatar
Default 94 Camry 2.2L crank no spark
So one day the battery’s dead go to charge it up and it’s good to go get out on the highway engine dies cranks no spark nothing the flashers work so the battery is not dead what could it be? I’ve replaced the Distributor cap and it is still cranking and no spark also there was a ice block in front of the radiator and water all over the engine bay When I popped the hood but took that out and now I’m getting a code for a oxygen sensor but that would not have killed the car would it? HELP
Old Jan 14, 2021 | 07:12 PM
Check for trouble codes. On this year of car, these can be outputted without a scanner. The internet should have threads on doing this.
Make sure the distributor is getting 12v.at the white/red wire that powers the ign coil.
Check ign coil body for cracking.
LISAND6395
Feb 24, 2018 11:13 PM
Asde33
Jul 12, 2017 01:02 PM
cwaite2
Mar 13, 2012 09:12 AM
organica
Jul 17, 2011 09:15 AM
almeece
Feb 16, 2009 07:32 PM
