Brief Engine Cutoff
Old Mar 2, 2022 | 12:55 PM
scasti1's Avatar
Default Brief Engine Cutoff
When warming up in cold weather, my 2001 Camry 2.2 engine briefly cuts off then immediately back on. When I first got it, it used to start up easy then kind of ease into a warm up. Now the engine runs real fast at cold starts, dies that brief cutout thing after about 60 seconds then proceeds to idle do an to 750 rpm when warm. Is my ecu going out?
Old Mar 3, 2022 | 01:47 PM
Read up on the Intake Air Control (IAC) valve. This valve control idle speed. It might benefit from cleaning or could be defective.
Old Apr 18, 2022 | 10:13 PM
Rennox's Avatar
Some suggestions,
+1 on IAC cleaning, make sure you get new IAC gasket(it will be brittle and break)
Check BVSV (can cause vacuum leak that has intermittent misfire) -> notoriously easy to break
Check your ignition switch contacts
Not sure if your make/model still has the cold start injector, could check that if you do
rulethestreet80
Jun 22, 2012 10:00 AM
reirson
Feb 13, 2010 01:33 PM
skyhi65
Mar 19, 2009 09:04 PM
arrowdragon
Aug 26, 2008 11:26 AM
wmthedirector
Feb 26, 2008 01:42 PM
