cam install help
Old Sep 24, 2008 | 06:42 AM
4speed's Avatar
Default cam install help
Hi all. I'm new here, nice forum.I've searched and can't find the answer to my question.
I have a 93 V6 that blew a head gasket at 170K miles. Rear dirvers side cyl. was sucking coolant. I removed both heads and they're at the shop getting checked now. Does anyone have the cam installation procedure before I go to the library and look it up? Is that posted somewhere? Thanks,
Old Sep 24, 2008 | 09:33 PM
Default RE: cam install help
The autozone website at www.autozone.com has a self repair section that covers this car and engine in good detail.
Old Oct 10, 2008 | 07:11 AM
4speed's Avatar
I'm just getting back to this project. I looked at autozone and I have a Haynes manual. Haynes says to line up the double dots on the Intake and exhaust cam gears. When I do this, the distributer and timing belt sprockets are off 180 deg. Autozone isn't real clear on lining up the single dot or double dots. I'm assuming Haynes is wrong and it should be the single dots.
Anyone run into this when installing cams?
I don't know how I could have anything else out. #1 is at TDC.
Thanks,
Old Oct 10, 2008 | 07:59 AM
If a 1MZ-FE engine then:
Rotate the crank to the No 1 cylinder at TDC. No 1 cylinder is on the rear bank and closest to the timing belt cover.
The double dots are used only to align the two cam gears with each other when installing in the head.
The single dot on the cam timing belt pulley is used when installing the belt. The dot on each pulley should be aligned with the mark on the timing belt cover.
After belt installation rotate the crank 2 times CW and check all marks to make sure they are still correct.
Camryfam1993
Aug 9, 2011 11:21 AM
DLW
Dec 29, 2010 04:35 PM
warbow7773
Apr 30, 2006 11:44 PM
V6 5spdSTEF
Feb 9, 2006 07:01 AM
V6 5spdSTEF
Feb 3, 2006 03:28 PM
