camry 98 with error code po446
Old Apr 17, 2007 | 10:10 PM
hmofeed's Avatar
Default camry 98 with error code po446
hi all
i have camry 98 and i have check engine code po446 (Evaporative Emission Control System Vent Control Circuit Malfunction )
i don't know what i do?
plz help
Old Apr 18, 2007 | 06:27 PM
toyoboy's Avatar
Default RE: camry 98 with error code po446
more then likely it the vapor pressure valve in the canister...to test the evap system it involves a scan tool and pressure tester....so unless you can get a hold of one or both of these...there's no point of telling you how to test then....try checking your gas cap for damaged gasket and reset the ecu (pull efi fuse for 5 sec) do this firt,,,your lightshould come back on,cause i don't think that the problem,...but thats an easy test to start with...you never know ..you mit get lucky
chips19023
Nov 9, 2009 11:16 PM
jhimer
Aug 29, 2008 11:34 AM
droopdog7
Dec 8, 2007 06:02 AM
mgoofy24
Sep 24, 2007 04:56 PM
red73mustang
Aug 15, 2007 12:27 AM
