Heating Camry 2005
Old Feb 1, 2011 | 06:14 AM
porubad's Avatar
Post Heating Camry 2005
I have Toyota Camry 2005 2.4 VVTi. This winter I have problem with inside heating. The temperature goes down from left to the right side. The warmest is on the left, almost cold on the right side. It is the same when AC is ON set also on max.
I already tried to change air directions (front, middle, down), close went hole, low / max heating.
Old Feb 1, 2011 | 10:16 AM
Could be one of the doors in the duct system under the dash used to mix and direct hot and cold air has problem. They may be electric operated, bad motor, stuck door.
Pinkie
Jun 15, 2022 01:50 AM
kinginca
Feb 2, 2011 10:17 PM
MuleDeerCrazy
Dec 10, 2010 04:07 PM
dogvila
Apr 30, 2010 10:44 PM
L.E.M
Feb 17, 2009 05:29 PM
