99 camry heating question
Old Feb 2, 2011 | 04:22 PM
kinginca's Avatar
Default 99 camry heating question
i have 99 the needle of themperture needle of my car is always rising when im on a full stop and when i accelerate it goes back down i changed the water pump radiator and fans what else could be the problem do i need to change the termostat?
Old Feb 2, 2011 | 04:36 PM
heyitsdatguy's Avatar
Burp the cooling system, thermostat....... that's what I can think of at the moment.
Old Feb 2, 2011 | 04:44 PM
kinginca's Avatar
how can i do that is something i can do or take to a mechanic?
Old Feb 2, 2011 | 10:17 PM
The AutoZone website has info on changing the T-stat in the sites vehicle repair guide section. You'll need to register (free).
You should be able to change the WP yourself, follow the lower radiator hose to the engine, the T-stat is in the housing the hose attaches to.
To burp the system, remove the radiator cap (engine cold) and squeeze the large radiator hose. If air in the system the air will come out and the coolant level start to lower.
Make sure the fans are working, should turn on with the AC compressor.
Pinkie
Jun 15, 2022 01:50 AM
porubad
Feb 1, 2011 10:16 AM
MuleDeerCrazy
Dec 10, 2010 04:07 PM
dogvila
Apr 30, 2010 10:44 PM
L.E.M
Feb 17, 2009 05:29 PM
