How to remove wiper motor from driver arm?
Hello,
I've removed the wiper motor, attached to the larger driver arm structure, from my '97 Toyota Camry and need to detach it from this structure. Here's what's still holding it on:
*The shaft of a bolt that comes out the bottom of the motor, passes through a metal panel to connect it to the driver arm structure, and then through a rubber piece and metal piece. The bolt, rubber and metal pieces are apparently part of the motor, as the same pieces came attached to the new motor I ordered.
It seems like these pieces need to slide off the bolt shaft, but they won't budge. I also can't get them off the new motor so I suspect they are meant to stay attached... ?
*Extending from the end of the metal piece that won't come off the bolt shaft is a snowman-shaped piece of metal: two *****, the base one larger than the one on top, with a metal lip at the top. The two driver arms are slipped over this, and seem to be held in place by a couple white plastic washer-like pieces that seem glued on.
This assembly rotates and twists pretty freely, but I can't actually pop it off the snowman-shaped piece.
Please let me know how to detach the motor from this piece! I'm so close! Thanks.
