Which parts should I check when "burning oil" found?
Old Jan 23, 2012 | 12:40 PM
volunteers's Avatar
Default Which parts should I check when "burning oil" found?
07 Camry, 4CL, 40k totally.
Since my last oil change (4 qt Synthetic Mobil1), it is about 4 months and 2800 miles. Right now only 2.5 qt engine oil left. I didn't find any leak outside. So which parts should I take a look inside for a possible leak? Thanks.
Old Jan 23, 2012 | 07:51 PM
The news may not be good. Suggest reading the tread below:
https://www.camryforums.com/forum/ge...sumption-3696/
Old Jan 30, 2012 | 04:09 AM
jmarshall098's Avatar
this problem seems to be common to the 07 Camry my friend is experiencing the same issue with this model moreover the dealers claims that 1/2 a quart of oil per 1100 miles or so is normal although they do not have any specifications on this to show
hope this helps
Old Jan 30, 2012 | 09:42 AM
Toyota released a service bulletin on this model of engine oil consumption concerns. T-SB-0094-11
It states 1 quart per 1200 miles is considered acceptable oil consumption.
If burning more then this AND the car is still under warranty the bulletin states to rebuild the engine under warranty.
How Toyota came up with 1 quart per 1.2K miles is speculation. Guessing the bean counters ran a few numbers and found this amount was high enough to keep the majority of car owners from qualifying for engine repairs before the warranty expired.
Old Feb 16, 2012 | 08:26 PM
tremonti23's Avatar
Cool oil consumption
I don't want to sound like a mobil 1 hater but Toyota does not endorse mobil 1 oil, they endorse Valvoline. Most likely cause is bad valve stem seals due to poor manufacturing. You aren't in warranty unless you have an extended one and that is what i would check first. Use valvoline from now on it has better wear performance anyway.
Staordwney
Jun 7, 2023 08:28 AM
mincheybs
Sep 19, 2014 05:54 PM
Amekaji87
Dec 4, 2011 02:39 PM
453126437
Oct 8, 2011 04:01 AM
peterliu2000
Aug 11, 2010 11:15 PM
