Clutch and difflock troubles
Old Feb 17, 2012 | 07:39 PM
Ballibt's Avatar
Default Clutch and difflock troubles
Im having some troubles with my 1988 Camry alltrac
the previous owner replaced the clutch and after that the difflock didnt work.
Any ideas on what it could be?
Also the clutch pedal is really hard to press down
Old Feb 17, 2012 | 08:25 PM
Isn't the diff lock actuator powered by a vacuum actuator. Perhaps the owner failed to hook up the vacuum plumbing?
For the clutch determine if the problem is the master/slave cylinder system or inside the bell housing. Watch the action at the clutch release arm and push rod coming out of the slave cylinder when someone is pushing up and down on the clutch pedal. Look for signs of binding, listen for strange noises inside the bell housing.
The master/slave system typically has issues with being too soft, not hard. Most likely the problem is inside the bell housing such as clutch pressure plate or somehow the release arm is not on its pivot point. If it is the pivot point you may be able to fix without taken the trans out.
Old Feb 19, 2012 | 10:45 AM
Ballibt's Avatar
thanks for the reply.
but i talked to one of the previous owners(there has been a ton of them since last summer) and he suspects that one of the vacuum hoses had a hole.
Old Feb 19, 2012 | 12:25 PM
The hole would account for the lock system not working but not for the hard clutch.
Makkybarr
Nov 17, 2009 06:00 PM
greenfire
Dec 16, 2007 09:19 PM
PhatElement
Jul 23, 2007 06:20 PM
frogger
Jul 17, 2007 04:31 PM
a1986camrydlx
Jan 25, 2006 09:06 PM
