Shaking Tachometer needle at idle
Old Jul 20, 2007 | 07:49 AM
steppinthrax's Avatar
Default Shaking Tachometer needle at idle
Essentially I got this 1999 Toyota Camry Yesturday it has around 30K on it. I notice when I'm at full stop at a light or when the car just started. The Tachometer needle seems to shake or vibrate a little bit. I kind of feel a vibration in the brake pedal as well. I'm guess this is indicating vibration in the engine. Anybody has any input on this or knowledge.
Old Jul 20, 2007 | 09:41 AM
nodrogkam's Avatar
Default RE: Shaking Tachometer needle at idle
idle problem.
could be a multitude of things, especially if it doesnt have a check engine light on.
you make have a loose vacuum hose or one with a small leak.
could be a slightly clogged fuel filter/air filter/idle air intake area
or the engine could be off balance ....and the list can go on.
ImportFan2013
Aug 22, 2013 10:49 AM
diegoaccord
Apr 9, 2013 09:41 PM
dolnishiabrown95
Dec 20, 2012 09:53 PM
rivaL*
Apr 2, 2007 03:32 AM
kimbee1022
Jan 26, 2007 12:24 PM
