Suggestions for specific brand of aftermarket oil filter equal or better than OEM
Old Mar 27, 2025 | 08:29 PM
camrycamry1952's Avatar
Default Suggestions for specific brand of aftermarket oil filter equal or better than OEM
First time Toyota owner, of used 2014 Camry SE Sport with 2.5 four cylinder engine. Which brand of aftermarket oil filters do forum members recommend? 110,000 miles, in excellent running condition. Uses no oil. Want to get 200,000 miles service life from the car, with accurately scheduled oil changes. Thanks.
Old Mar 27, 2025 | 10:22 PM
Most moderate intermediate level oil filters will be just fine. I'd steer clear of the budget oil filters (Fram, no name, etc). I'd also steer clear of lower level/mid tier filters, think silver line stuff, etc.
I would do NAPA Gold, Mobil 1, etc.
All that being said, someone else can come along and say the opposite. Filters aside, be sure not to skimp on the oil quality. I'd rather have better quality oil than the filter. Has your car used 100% full synthetic or the typical synthetic blend? Stick with what your car has been using because it is the four cylinder and it is not using oil, a common issue with the four cylinders.
Old Mar 28, 2025 | 09:31 AM
The higher end NAPA filters are good. NAPA Gold. Years ago WIX made NAPA but now someone else.
WIX is owned by Mann Hummel a large filter making corporation.
Toyota owns a large share of Denso Corp who apparently makes Toyota filters. Denso has been great with all their products.
Bosch makes good products but some complaints about filters made in Mexico.
There various levels of filter performance within the same brand. See link below:
https://www.rockauto.com/en/catalog/...il+filter,5340
If your going 10K between changes might look at an extended life filter.
Also take note of where you buy your filters as there are fakes out there, be careful of Ebay and Amazon.
1RedPatriot
Oct 13, 2021 10:00 AM
reynoldston
Jan 26, 2016 02:02 PM
EZDriver
Oct 9, 2014 03:46 PM
yjk1975
Nov 23, 2009 08:03 PM
paul0
Jan 25, 2008 11:48 AM
