weird stalling
Old Oct 15, 2007 | 05:56 PM
groggrog's Avatar
Default weird stalling
just replaced the transmission in my 97 camry, at the same time i thought while the engine was out i'd install some seals, replace thetiming belt, new water pump, pulled the oil pump checked it for clearnce,pulled the head for new head gasket, new intake/exhaust gasket...torqued everything down per specs, cleaned the timing sproket and crank sensors. now car starts good when cold but when hot and in netreul car stalls intermintly, water temp gaugemoves irradically but mostlysteady...oh yea i broke the tempature sensor off when removing the motor and replaced it with one from 1994 (junkyard) it looks the same went right in. car has 170k ran excellent with slipping transmission. when car is ideling and i rev it up to 3000 rpm engine will cut out and stall then hard to start.....no codes....... thank you Roger
bigstew25
Mar 2, 2008 04:20 AM
pippo
Dec 1, 2007 12:51 PM
Blue07CamNY
Nov 4, 2007 06:13 PM
sjm999
Dec 15, 2006 05:20 PM
jnatoli77
Jul 9, 2006 10:02 PM
