1998 camry
Old Jan 15, 2007 | 03:54 PM
tommack's Avatar
Default 1998 camry
187k miles told timing belt changed about 60k ago. If this belt breaks will it hurt anything? Should I change it to just be on the safe side? thanks.
Old Jan 15, 2007 | 08:36 PM
nodrogkam's Avatar
Default RE: 1998 camry
Check belt for signs of cracking, drying out, or looseness. You probably should change it. The part itself is cheap just labor is expensive if you dont know how to do it yourself.
It should be an non interference engine meaning no damage if it breaks, just the car will stop.
So take a look and make a decision.
Old Jan 17, 2007 | 03:37 AM
Joel_CA's Avatar
The timing belt on the 4cylinder engine gets fairly noisy with a loud rattle coming from beneath the timing cover once the timing belt stretches out. This occures anywhere between 2000-3500 RPM. If you hear this rattle, consider changing the belt as soon as money allows. No mechanical damage will result from a broken timing belt- but do it for safety's sake.
J
Old Jan 17, 2007 | 02:50 PM
tommack's Avatar
Thank you. Love this forum. I own 3 toyota vehicles and this is very helpfull.
Old Oct 17, 2007 | 10:45 AM
Anas's Avatar
i have a 98 camry...it has 162K on it....the last time the timing belt was changed was on 110K....should i go ahead and replace the belt...and also can you tell me what is the lifetime of the timing belt considering it has been driven normally....
thanks....
Old Oct 18, 2007 | 04:06 PM
nodrogkam's Avatar
timing belt should be changed around 60K and can last up to around 90K before failure depending on particular situation.
moreover, with the v6 it is non interference so besides being stranded somewhere and needing a tow, engine will not be damaged.
lavalleemike
Aug 11, 2006 12:29 PM
craiggo
Jun 3, 2006 04:20 AM
lavalleemike
May 6, 2006 03:21 AM
jetstopi
Feb 4, 2006 02:10 PM
TriumphGT6
Jan 8, 2006 07:56 AM
