09 Toyota Camry SE issue
Old Oct 29, 2021 | 02:32 PM
Jamie's Avatar
Default 09 Toyota Camry SE issue
I have a 09 toyota camry se and I had been hearing at first a squealing noise when cranking up the car but it didn't last long. So then I was experiencing an issue with my headlights driving in the and the motor would jerk a little bit. So I did some research and found out that it could be the serpentine belt so I replaced that. Well now I noticed when I turn the ac on I hear a clicking noise. Could my tensioner be going bad or could it be the ac compressor? I do get good cold air from the ac.
Old Oct 29, 2021 | 05:27 PM
When changing the belt did you spin test all the pulleys for rotational freedom?
Use a section of rubber hose as a stethoscope to narrow down the noise area.
Old Oct 29, 2021 | 06:57 PM
Jamie's Avatar
The pully did spin ok, I'll try the hose idea.
Thank you
Jsrich28
Apr 1, 2019 11:02 AM
david93
Jul 16, 2015 04:31 AM
tainted
Sep 23, 2012 01:29 PM
maxcherry
Jan 7, 2012 10:06 PM
bslevy3477
Oct 9, 2010 06:42 PM
