1990 camry seat belts
Old Mar 10, 2009 | 01:56 PM
mike7's Avatar
Default 1990 camry seat belts
Hello all, my friend has a '90 camry with automatic seat belts. The retractor motor works fine but the belts don't trip when you brake or at all actually. They're not safe. Is this a mechanical piece on the belts or electric? Should he get new belts or can it be fixed...also if someone could give a link with a part number it would be appreciated. Thanks.
Old Mar 10, 2009 | 08:16 PM
Try pulling the belt out rapidly and determine if it locks.
Old Mar 11, 2009 | 06:55 PM
mike7's Avatar
No, it doesn't. I think there is some electric sensor on these types of belts that controls the locking mechanism correct? I've always worked on older GM cars so I don't know much about these ones. He doesn't want to spend 200$+ for new belts on either side so I'm considering a swap from a salvage yard or at least lap belts from another car.
Old Mar 12, 2009 | 12:35 PM
Have never worked with automatic belts.
Did not think these early Toyota's had any type of electric belt lockup on the seat belt
The belt should be bolted to the frame at lower outside center chassis column. Typically you can remove the column trim piece to access the belt reel and locking mechanisum.
The belt system may use a stationary weighted pendulum or ball that moves foward when the car brakes rapidly or stops moving forward. The weight moves forward, the arm it is attached to locks the belt.
This locking system may be differant from the ones where pulling out the belt too fast activates the locking device.
In this case the locking device is attached to the reel the seat belt winds up on. If the reel rotates to fast, the weighted arm of the locking device is thrown outward and locks the reel.
Old Mar 12, 2009 | 02:44 PM
mike7's Avatar
Yes, I understand how seat belts work thank you. I am asking how this particular belt works and I do believe it has an electric switch on the retractor as almost all foreign cars do. The mechanical parts rarely, if ever, wear out from use (for example - this is why American seat belts from the 50's still work). It's usually the switch which goes, does this car have an electric switch on the retractor? If it does, there is no point in swapping for another old one from a junkyard because that one could be broken also. I'm considering just swapping for a free pair 3-point mechanical belts from an old G body for him, at least it'll be free that way.
Old Mar 13, 2009 | 08:17 AM
Yes, a spool release switch.
bobw1008
Jun 9, 2015 07:53 AM
mightymatt40
Aug 20, 2012 09:38 AM
r0cky
Jun 9, 2007 05:56 PM
ivershay
Jan 23, 2007 11:16 PM
