1990 will not start
Old Jul 9, 2011 | 04:54 PM
macowan61's Avatar
Default 1990 will not start
I have a 1990 camry with about 170,000 miles on it. I was in the jack in the box drive thru when it died and will not restart. It cranks over fine. The timing belt is fine. I have spark and fuel pressure at the rail. I checked all fuses and they are fine also. Any ideas? Do these have a crankshaft position sensor on them?
Old Jul 10, 2011 | 11:00 AM
V6 or 4 cylinder?
There are no remote crank or cam sensors. All the sensors are built into the distributor.
Fuel pressure should be something like 33-44 psi depending on what test is being done.
Is the spark hot, as in able to jump 1/2 inch or more of gap?
Old Nov 23, 2011 | 07:46 AM
Scrumpilump2000's Avatar
How did you make out with that? I have a 1990 Camry which would turn over but not start. It was the ignition coil. Replaced it (at about $90.00) and it fired right up.
Cheers,
-Mike
Scrumpilump2000
Nov 23, 2011 08:10 AM
brandon_bauer
Jun 18, 2010 12:46 PM
lukaskliz
Feb 13, 2010 09:42 AM
ejmaue
Jan 18, 2010 01:07 AM
90Camry
Oct 24, 2007 11:26 AM
