1992 Camry 2.2 Manual Trans Problem
Old Oct 19, 2015 | 02:06 PM
Speedemon636's Avatar
Question 1992 Camry 2.2 Manual Trans Problem
Hey everyone. Im new to the forums.. I have a 1992 Camry 2.2 with the 5spd manual trans. A few weeks ago it started popping out of 5th gear. If I don't physically hold it in gear, it will randomly (violently) disengage. Im assuming a bearing let go because it had bad slop in 5th and in 3rd. I didn't see anything to adjust really and can't find hard parts for a trans rebuild. Am I just going to have to replace the trans? Car has 231k on the odo - not sure if its the original trans or not, but it probably is.
Thanks for any help or direction!
Old Oct 20, 2015 | 01:33 AM
dirty hands's Avatar
check your engine mounts while looking around under the bonnet
if it is a syncro .... might be best to swap the box out for another
should be an E5 series manual gearbox this is the gearbox parts list
http://www.manualtransmissionpart.com/E51.html
Old Oct 20, 2015 | 01:42 AM
Sounds like a syncro to me. Requires transmission rebuild.
fizzle
Oct 22, 2011 12:38 PM
Spacinjason
Mar 8, 2011 09:36 PM
j.hs 97 camry
Sep 14, 2009 03:14 PM
kyle3080270
Jun 3, 2009 03:34 PM
