1992 Camry 2.2 Missing and won't idle without dying.
Old 06-23-2014, 11:05 AM
May be good news. Not starting may be easier to diagnose then this miss.
For timing belt, check if rotor is rotating when engine cranked. If OK, check for ign spark. Spark should be able to gap 1/2 inch of air, white colored spark is best.
If spark try applying throttle when cranking.
VSV is a electric vacuum valve. Should be closed at engine off and idle, no vacuum getting to EGR system from engine intake manifold. Being closed turns off the EGR system.
Has happened the signal coils inside the distributor fail. This can be checked for ohm resistance. Is the coil built into the distributor or separate?
  #12
Old 06-25-2014, 07:35 PM
Odstoro's Avatar
Ignition Control Module was the problem which is $250.00 at the local Napa but $25.00 at the Junk Yard.
Thanks for all the help, hope this helps someone else!
  #13
Old 06-26-2014, 11:49 AM
Great job! Thanks for posting back with the fix.
worstfootball
03-21-2010 09:47 PM
Karl99
11-15-2009 10:18 PM
Avantgarde
02-03-2008 05:52 AM
cmrylovr
07-30-2006 05:10 PM
Quick Reply: 1992 Camry 2.2 Missing and won't idle without dying.
