1994 Camry V6 LE (Japan) High Idle
Old Apr 10, 2010 | 01:46 AM
runner5113's Avatar
Default 1994 Camry V6 LE (Japan) High Idle
After my tune up, Changing spark plugs, sprayed air plenum holes with carb cleaner and wiped it off as far as I could reach, also sprayed and cleaned the plenum, throttle body, iac, changed the air filter, it had a hard tissue stuck in the old one, with alot of oil deposit, now it has a higher, stronger pitch idle that sounds preety clean, but it's not the same as when it was before, at factory specs I guess, I can't remember what it sounded like when it was new, Should I be checking or adjusting anything, if so what things should i look at?
Thanks in Advance,
mindful123
Sep 24, 2014 08:11 AM
k2hara
Jun 28, 2011 11:38 AM
runner5113
Apr 10, 2010 01:38 AM
mazdabate
Feb 11, 2009 09:05 PM
marc780
Apr 10, 2006 06:22 PM
