1994 won't fire
I have a 94 with a 2.2 that just turned over 235000 miles. It has been running great even in sub zero temps but now will not fire. It died while I was driving and now will not fire at all. Any ideas? I have replaced the fuel filter to no avail.
Thanks
Thanks
Thanks for this post. I too had the exact same problem on a 2009. I took it to the dealer and they said the ABS Actuator needed to be replaced and wanted $2500 for the work...crazy...so I took it back home. Found this post and went to work. However, My issue was different. I found it to be in the hookup connection. I took it apart looked for different concerns, did not really see anything. I cleaned the connection points with alcohol and made sure all were straight. None of this really made a difference. So I took a mirror and placed it behind the steering wheel so I could see when the lights came on and off and began to apply pressure to different areas of the connection until I would see the abs and break light go off. I found with a slight bit of pressure between the connection and the unit the light would go off. I am sure a pro would take all this apart and repair it correctly, but I created a plug that fit between the unit and the connector that maintained the pressure and wedged it in. Everything now works great. I say why remove gnat with a hatchet?
y13supio
Oct 4, 2010 12:12 PM
mindle374
Sep 21, 2010 10:56 AM
