1995 Toyota camry v6 le sedan - how hard to remove front struts
Old Feb 21, 2016 | 11:50 AM
  #11
wdc123's Avatar
Correction - the bearing should be the opposite way.
Old Feb 21, 2016 | 12:02 PM
  #12
Which way is the opposite way?
Old Feb 21, 2016 | 12:09 PM
  #13
wdc123's Avatar
There is one face of the seal that has an red colored inner seal as seen on the picture and that faces down. The other side has an outer rubber seal facing up. Correct?
Old Feb 21, 2016 | 12:12 PM
  #14
wdc123's Avatar
The seal in the strut mount should be flipped showing the red seal
Old Feb 21, 2016 | 03:18 PM
  #15
My take is the red seal should face inward. As in when the strut is installed be closest to the strut nut that holds the mount together.
The bearing can only work one way. If upside down the edge of the outer race will ride on the or mount. The loading needs to be on the faces of the bearing not edge.
Old Feb 21, 2016 | 04:55 PM
  #16
wdc123's Avatar
OK, Thanks
Old Feb 28, 2016 | 09:34 PM
  #17
wdc123's Avatar
The suspension repair went well. Will be getting new tires and alignment soon.
Some comments are here. 1995 Toyota Camry V6 build 6/95
1. Never compressed a new spring before since the original broke. Very difficult to compress it straight down. I was 180 out of sync but required using different wrungs to make it work. Spring must be straight to seat properly. The compressing tools I rented at oreillys are great. No issues.
2. Had to drill two holes to allow lower spring pad o seat properly. The original one was still in good shape and had two rubber nipples that fit in strut holes but new strut did not have them.
2. A hammer drill though not recommended for compressing strut works well otherwise your arm will hurt using socket a wrench.
3. Take apart first, inspect,then buy to ensure you have all the parts you need.
4. The strut mates all in one are easy but more expensive.
Oh after I installed everything the springs and strutsere so bad the front end went up " three inches" at least. The back did the same last year when I did it but springs were fine.
Old Mar 2, 2016 | 11:28 AM
  #18
Great write up!
Thanks for posting!
brianjrealtor
May 30, 2023 04:03 AM
wdc123
Dec 9, 2015 01:47 AM
wdc123
Dec 8, 2015 10:10 PM
markmmv
Jul 2, 2012 07:06 AM
rutwad
Mar 29, 2009 08:28 AM
