1999 start up rattle
Old Jul 7, 2010 | 07:05 AM
cmamtm22's Avatar
Default 1999 start up rattle
i have a 1999 camry 4 banger that makes a noise like it has no oil when starting. this happens every time the car has sat for about 15 minutes or more. i changed the oil filter and it was totally dry inside. apparently the oil is draining back while sitting. any cure for this? the car had a WIX filter and i changed to a PureOne whith no change in noise. other than this issue, car runs perfect.
Old Jul 7, 2010 | 03:07 PM
Any possibility of a clogged oil intake screen.
Old Jul 8, 2010 | 08:33 AM
cmamtm22's Avatar
at this point, i can't rule out anything, but i would think a clogged oil pump screen would cause low oil pressure all the time. this one acts as if the oil pressure bleeds off while sitting. 2 seconds of rattle at startup and all is well...
Old Jul 8, 2010 | 09:39 PM
How about engine sludge? Remove the valve cover to take a look.
Old Jul 12, 2010 | 09:02 AM
cmamtm22's Avatar
looks very clean under valve cover. i'm thinking its a loose rod bearing clearance or something deep...
lpatti31
Dec 5, 2012 02:55 AM
Keyria
May 2, 2008 06:36 PM
KillaCam86
Dec 6, 2007 11:30 PM
natnoo
Nov 12, 2007 08:19 PM
starbase47
Oct 29, 2006 01:38 PM
