2000 Camry Check Engine Wont go away Pls Help!!!!!!!!!!
Old Oct 4, 2008 | 01:55 PM
Taheezie's Avatar
Default 2000 Camry Check Engine Wont go away Pls Help!!!!!!!!!!
HI I have a 2000 Camry and my check engine light keeps coming on.I diagnosed it with the OBD code reader and it gave 4 of the
following codes : Codes are "Pending codes PO441 and PO446". and "Regular codes PO441 and PO446".When the check engine light is on with these codes I get extremly low gas mileage, but when I clear the code its back to normal,but it comes back on, so I need to permanently fix this problem.Any help would be greatly appreciated.
Thanks,
Old Oct 4, 2008 | 03:29 PM
pedro's Avatar
Default RE: 2000 Camry Check Engine Wont go away Pls Help!!!!!!!!!!
http://www.obd-codes.com/forums/570-...440-p0441.html
Old Oct 18, 2008 | 10:18 PM
Taheezie's Avatar
That website did not help too much pedro, anyone got any other ideas
Old Oct 19, 2008 | 04:37 AM
pedro's Avatar
When you say it didn't help, what did you do with the information provided on that link? Did you do any troubleshooting? If you're getting low gas mileage and those codes indicate a problem with the evap system then it sounds like your purge valve may not be operating correctly and drawing raw gas into the engine. Are you getting any problems with engine idle?
pknkak
Nov 4, 2013 08:48 PM
epschaub
Aug 3, 2011 02:08 PM
chilllaxeng
Apr 11, 2009 03:54 PM
conkers15
Jan 24, 2008 05:08 PM
