2001 Camry Stalling Problems
Old Mar 19, 2012 | 08:52 PM
KWali24's Avatar
Default 2001 Camry Stalling Problems
I apologize if this thread has been created because I haven't really looked through the threads.
My Camry has had this stalling problems for like 3-4 months now. These problems occur after driving for 20-30 minutes of driving in high speeds such as 60-70 mph. The rpm starts jumping up and down between 250-750 and the car just completely dies. This isn't good because I've almost experienced numerous accidents. The car would stall when I take my exit off of the highway and when I come to a red light or a stop sign. I'm so frustrated with this problem because I've made numerous attempts to fix this problem and the mechanic doesn't seem to find the problem.
From this problem, I've changed/installed:
-Alternator
-TSP censor
-Did a tune up
and none of this has fixed the problem. So if anyone, please can help me out with this problem
Old Mar 19, 2012 | 09:05 PM
ukrkoz's Avatar
No, this is not good. I do second this opinion.
Can you read engine error codes BEFORE tossing unnecessary repairs and lightening your bank account?
You mean- TPS? throttle position sensor? what kind of tune up? ever looked at idle speed control valve?
READ CODES. it's free any parts store.
Old Mar 19, 2012 | 09:50 PM
KWali24's Avatar
What do you mean by read codes?
Old Apr 15, 2012 | 04:05 PM
Shu76's Avatar
Autozone will hook up a scan tool and scan for a code to locate where the problem is coming from.
Did you change out the fuel filter? , that can cause the car to stall since if it's clogged, gas can't pass through it.
Check the Mass Air Flow Senser and clean it with some Mass Air Flow cleaner. Don't use anything else.
Shannxx92
Dec 25, 2011 10:11 AM
joestimec
Jun 12, 2010 12:32 PM
tonyhatchetman
Apr 12, 2010 07:35 AM
jeeperman
Oct 27, 2008 08:19 PM
babykm
May 16, 2007 03:46 AM
