2002 ac problem
Old May 19, 2009 | 02:03 PM
DerekG's Avatar
Default 2002 ac problem
Hey,
I have a 2002 camry. The ac cycles between cold and warm every 30 seconds. I added freon, replaced a relay and replaced the cabin filter a couple of months ago. Does anyone have any suggestions on what to look for now? Thanks.
Old May 19, 2009 | 04:05 PM
pedro's Avatar
Not enough info to even guess. Without pressures it's a crap shoot. Why did you think it needed Freon (r134a)? Automatic climate control or manual? Could be evaporator thermistor?? Id' take it to an A/C pro otherwise you're shooting in the dark.
Old May 19, 2009 | 08:01 PM
zcpro's Avatar
Smile Had similar problem 2003 SE
Check to see if FAN # 2 is on (spinning) when you have the A/C on. This will cause the compressor to heat above normal operations and provide poor cooling performance. I replaced the fan motor and it was back to new car A/C again!
Old May 20, 2009 | 10:55 AM
DerekG's Avatar
Pedro-The ac would not cool.
zcpro-Both fans are turning.
I guess I will have to take it in to a shop. Now when you are idling and the a/c starts the car almost dies. Hopefully its not the compressor.
Old May 20, 2009 | 02:35 PM
pedro's Avatar
There is an idle-up when the compressor engages, it may be that. If the compressor is so bad as to cause that kind of drag to the engine I think it would be making some god awful noise. I doubt an 02 would have the compressor go bad unless you ran it low on oil - that would occur from continued leaking then refills without oil.
brzwarmwind
Feb 8, 2014 11:32 PM
Dnablood
Jan 17, 2011 09:57 PM
KaFa21
Jan 16, 2011 04:29 PM
snation
Aug 22, 2010 11:57 AM
aemravan
Jul 10, 2010 03:17 PM
