2003 camry low idle stall
Old Sep 9, 2017 | 07:41 PM
Drewcar's Avatar
Question 2003 camry low idle stall
a check engine light came on 2003 camry 2.4L auto. OBD fault code was P2238
the car has 150K miles so I changed the following.
coil packs. Plugs. Air/Fuel ratio sensor. MAF sensor. O2 sensor. + side battery post. the check engine light is now off but I now have a very low idle that cuts the car off at red lights or stop signs. Any ideas on what to do to fix.
Thanks
Old Sep 9, 2017 | 10:36 PM
P2238 is a fault in the A/F sensor heater circuit, Bank 1 Sensor 1.
Disconnecting the battery will cause the engine computer to relearn the idle RPM. Keep driving until the computer relearns the idle.
Linnea Heatley
May 16, 2017 02:43 PM
Brian Gilbane
Nov 30, 2016 02:08 PM
just2day
Dec 19, 2012 09:40 PM
iamtfc
Jan 16, 2009 07:07 PM
fixitguy63
Mar 28, 2008 07:34 PM
