2003 Camry V6 - vacuum hoses at front of trans...
Old Feb 24, 2022 | 07:37 PM
OhWhatAFeeling's Avatar
Default 2003 Camry V6 - vacuum hoses at front of trans...
What are these two vacuum hoses going to a solenoid down between the trans pan and the subframe behind the radiator? One was disconnected and it was a bitch to get it back on due to limited space. No check engine light with it disconnected.
Old Feb 25, 2022 | 05:23 PM
Can you post a photo of the solenoid in relation to the engine?
Follow the hoses from the solenoid to find where they go. One has to go to the item being powered by vacuum. Describe or take a photo of that item.
Old Feb 25, 2022 | 05:32 PM
It would be very hard to get a pic because the solenoid is buried between the trans pan and the front cross member. The two hoses that go down there terminate at the air filter box and a little box mounted to the side.
You can see the twin hoses in this pic.
Old Feb 25, 2022 | 08:16 PM
The hoses appear part of what Toyota calls the Air Intake Control System.
The purpose of the system is to vary the size of the intake air chamber. This to achieve a lower air intake noise and increase power. It’s a way to change the intake air cleaner box volume which effects intake noise and engine power.
The air cleaner has two air inlets. At low to mid range engine speed, the control operates the air intake control valve to close one side of the air cleaner inlet. At high-speed range the control operates the air intake control valve to open both side of the air cleaner inlet.
The computer self check system may only check of the solenoid is working electrically, not if the actually system is working.
Old Feb 26, 2022 | 04:29 PM
Thank you for the detailed reply. I got the system reconnected and all is well. My intake noise was strange when I first got this car so maybe this might just rectify that. Thanks again.
Williambertram@yahoo.com
Jan 7, 2022 12:50 PM
idealg
Mar 14, 2012 08:40 PM
1985sr5
Aug 11, 2011 10:32 AM
brianjrealtor
Feb 3, 2011 06:45 PM
lilbluescout63
Aug 9, 2009 03:16 PM
