2004 SEV6 shifting hard/late? Why?
Purchased a loaded SEV6 with 60k a couple months ago. It's a pretty car, but I'm a little concerned about the transmission's behavior. I previously owned a 2000 Camry LE 4 banger and even at 140k it shifted effortlessly. So it comes as a surprise that my new car hesitates, hangs, and then snaps into gear. This happens mostly at lower speeds, between 20 and 40 I'd say. It's actually given me a noticeable jolt a couple of times. This seems out of character for a Camry, no? I couldn't find any info on TSB's for this. What could be going wrong?
Definitely not an overdrive issue, and I'm pretty certain a newer Camry with relatively low miles wouldn't be having mechanical transmission problems. I've seen some info around the web about a computer reset but can't pin down specific information.
Maybe I'll try this from a different angle. Does anyone have a list of TSB's for my car? Alldata says there is one specifically addressing my problem but doesn't get more specific than that. Please?
I did purchase an extended warranty so if anything is wrong with the transmission itself it can be fixed. I was just thinking if there is indeed a TSB, which is what it looks like to me a dealership would have to do it. I just have trouble believing that it's a mechanical transmission issue. I've been through a Supra, Corolla, '00 Camry, tC, Prius, and now this car with no hint of trouble well over 100 and some 200k. Well, other than the technological hiccups on the Prius....but that's what I get for purchasing one of the first ones off the line after the redesign.
jm3a01Camry
Oct 12, 2009 10:43 AM
