2007 camry towing trailer
Old Dec 21, 2009 | 08:42 PM
janvds's Avatar
Default 2007 camry towing trailer
Hi-
I've just registered in this forum. Has anyone had experience towing a trailer with waverunner, ATV, or snowmobile behind their 2007 (or smilar) Camry? I have the LE 4 cyl.
Please let me know. Thanks!
Old Dec 22, 2009 | 12:28 PM
What does the owners manual state. The typical towing limit for Camry is 1000 lbs.
I tow a trailer on occasions behind an earlier model 4 cylinder Camry.
The car can tow 1000 lbs (total weight) without problems.
Max load towed was around 2500 lbs. Would only recommend this for short distances such as getting a load home from a local store. This load is too heavy for safe higher speed travel.
When towing loads over say 700 lbs suggest turning off the O/D.
The cars MPG drops significantly when towing even just the empty trailer (est weight 450 lbs).
If I was going to tow loads over 1000 lbs on a ongoing basis would be looking at an trans oil cooler.
In some states any load over 2000 lbs require trailer brakes.
Suggest you limit the load to under 1500 lbs, and under 1000 lbs ideal.
Old Oct 29, 2010 | 09:15 PM
nortondlcl's Avatar
Whats the difference between 2006 camry V6 with 2000lb towing And A 2007-2011 camry that only has A 1000lb rating?
WTF!
2006 has 107 wheelbase & 190hp
07-11 has 109 wheelbase & 268hp
xs1
Aug 23, 2013 05:35 PM
nortondlcl
May 29, 2010 12:36 AM
welby
Aug 31, 2009 10:08 PM
jderrick
Jan 14, 2009 06:05 PM
getoutside77
Aug 11, 2008 04:54 PM
