2009 Camry Hybrid has DRL but no Low Beams
Our '09 TCH has DRL lamps that light whenever the car is turned on (day or night) but the low beams don't come on at night. Makes it dangerous to drive at night with very little light. High beams work fine. Both Low Beam fuses are OK. I've illuminated the round sensor in the top/middle of the dashboard with a lamp and the dashboard lighting gets dim and bright, so the sensor is working. Am I missing something obvious? Unlikely to be both bulb ground connections. Simply won't switch from DRL to Low Beams at night.
dsmith222
Oct 23, 2009 09:53 PM
