2009 Camry Hybrid Heat Problem
Old May 26, 2022 | 06:15 PM
curtarseneau@gmail.com's Avatar
Default 2009 Camry Hybrid Heat Problem
I have heat coming from the dash vents even with the heater-a/c turned off. Other heat-a/c functions seem to work fine. Would you blame the heater valve? Is the heater valve in the open where I can watch it's action when I switch the heater on? What is your recommendation?
Old May 27, 2022 | 12:49 PM
Toyota eliminated the heater valve that regulated coolant through the heater core. The system has a plenum where hot and cold air mix based on the position of the "blend door". The door is controlled by a small electric motor.
Old Jul 11, 2022 | 04:33 AM
Alpoi's Avatar
I have a toyota camry 2008 LE and it functions so well.
snaptube vidmate
alrayo@icloud.com
Oct 25, 2019 01:56 PM
Saxon Racer
Mar 16, 2011 03:13 AM
Saxon Racer
Jan 24, 2011 04:56 PM
tystuh
Feb 20, 2010 10:36 AM
mrpackrat
Dec 26, 2006 10:16 PM
