2011 Camry Poor Radio Reception
Old Dec 24, 2014 | 02:10 PM
dmarr35's Avatar
Default 2011 Camry Poor Radio Reception
I know it has been talked about but has anyone solved the poor radio reception on the Camry rear window amp ant. Everything works but it does not get certain channels and if in garage nothing . the amp works does anyone have an idea as far as a aftermarket antr fix or should I replace with external ant.
Old Dec 25, 2014 | 11:01 AM
Might be the antenna connection at the rear. The link below shows the location in one of the posts.
Car Audio issues, FM Static, HELP - Automotive | DSLReports Forums
Make sure all wire connections are making good contact as opposed to the plug just being connected.
Is the the radio amp you check or antenna amp?
Sometimes the wire connection to the antenna on the glass is bad.
Danny88
Dec 26, 2013 12:33 PM
coops0812
Jan 10, 2011 05:35 PM
brianjrealtor
Feb 14, 2010 03:44 PM
AsianScene
May 12, 2009 05:03 PM
azur
Jan 20, 2009 09:37 AM
