2018 Toyota Camry XLE Hybrid
Old Oct 15, 2019 | 11:17 PM
kilo11's Avatar
Default 2018 Toyota Camry XLE Hybrid
I bought a 2018 Toyota XLE Hybrid on Nov. 01, 2017 I am having a problem with the tires wearing out on the inside. I did alignment in 2018 and this spring. Today I went to get my winter tires on, and saw the wear, the tires are almost not usable with the inside wear.
I am wondering if anyone else has run into that problem?
I have about 27,000 KM on them, Bridgestones that came with the car.
Thank you in advance.
PS: I scheduled another wheel alignment next week. And my winter tires are wearing on the inside too, not to the same extent as I have a lot less millage on them.
Old Oct 16, 2019 | 08:23 PM
All tires or front/rear?
Are you rotating the tires?
Is tire pressure OK?
Old Oct 16, 2019 | 08:55 PM
kilo11's Avatar
The tires are wearing on the inside as said, all 4, but the cause is the rotation.
the pressure is ok, keep a good check on that from inside the car and pressure gauge.
Old Oct 17, 2019 | 12:53 PM
You think the cause is the tires being rotated?
Find an alignment shop that can go beyond a standard checks. Some alignment adjustments need an added kit to preform.
Read up on camber kits.
https://www.google.com/search?q=camb...hrome&ie=UTF-8
Old Oct 17, 2019 | 01:12 PM
kilo11's Avatar
Thanks, I will look into that.
Lorraine Netretic Abraham
Nov 12, 2015 09:22 PM
ginakins77
16
Aug 21, 2015 02:38 PM
00Camry
Apr 9, 2015 11:51 PM
bookemdano
Jun 13, 2012 08:28 PM
jlee1112
Jan 8, 2009 08:25 AM
