87 Camry 2.0 Manual Question About Engine Idle Dropping Down Low
Hello to all I have a 87 Camry 2.0 manual and have the following problem. Only when the car is extremely hot (been driving it a while) and then you turn off engine then try to start it again after 2 minutes or so the car will start right up but the rpm's will drop way low to 400 sometimes lower and sound like it will cut off. The problem so far is easily fixed by giving it a lot of gas then driving the car or turning the car off and starting it again. The wired thing is it only does it intermittently not all the time and only when the car is hot and has been driven a lot.
Things I have done to try to fix this. Taken off the EGR and try to clean it. It was so dirty I replaced with new EGR. After replacing the EGR it has only done the same problem 2 times again but not as bad as before replacement of EGR. However it still did it 2 times after replacing EGR which indicates to me there is another problem at hand here. The car also has a new radiator, starter, battery, alternator, thermostat, air filter, belts all, and a new radiator cap. Please advise and help me as to if someone out there on the forums knows what this problem is or has experienced a similar problem and what can be done to fix this problem. Thanks very much for you help.
Dave
Dave
hardyrxp
02-08-2011 06:07 AM
hardyrxp
05-02-2010 09:11 AM
hardyrxp
04-02-2010 12:19 AM
hardyrxp
03-20-2010 12:09 AM
