87 Camry ? about idle dropping low after starting the car when it is hot?
Old Apr 2, 2010 | 12:19 AM
hardyrxp's Avatar
Default 87 Camry ? about idle dropping low after starting the car when it is hot?
Hello to all,
I have a 87 Camry 2.0 5 speed and have a problem with the idle dropping low when I start the car ONLY after it is extremely hot (been traveling far). The weird thing is it only does it intermittently and it can easily be fixed by either giving the car a lot of gas (revving up the motor) or turn the car off (or let it conk out) then restart the engine. Okay so I am giving up here the following is a list of what I have done to fix the problem.....
egr valve replaced & cleaned, egr valve solenoid/modulator inspected and tiny filter replaced, all vacuums lines inspected visually and by hand thoroughly, sensors i.e. tps and numerous others unplugged while the engine was running to test them and make sure they were working properly. In addition throttle body cleaned thoroughly, pcv/hose/tube cleaned & replaced. So again I am perplexed here as to what to check next or where to look? Can someone please help/advise me here and what to look for next and what they thing it might be. I am sure someone on these forums has had it happen to them or something similar look forward to hearing from you thanks.
Dave
hardyrxp
Feb 8, 2011 06:07 AM
hardyrxp
May 2, 2010 09:11 AM
hardyrxp
Mar 20, 2010 12:09 AM
hardyrxp
iamtfc
Jan 16, 2009 07:07 PM
