91' turn signal noise
Old Nov 19, 2006 | 12:09 AM
neenie484's Avatar
Default 91' turn signal noise
When I put my turn signal on to turn left and then make the left turn I hear a buzzing noise around the dash area. Has this happened to anyone before. thanks
1991 Camry
Manuel Trans.
4 cyl
Old Apr 30, 2009 | 12:59 AM
keatingr's Avatar
Default Same problem, cleaned contacts
I also have a 91 which makes an odd 'electrical' buzzing sound when I flip the turn signal for a right turn. The sound comes from under the dash, near the round relays. But it does not happen everytime. If I pull the turn signal lever firmly, then I usually do not have it. If I move it softly I generally will have the noise. I figured its related to dirty contacts in the turn signal lever on the steering column. With the car off, and the key out of the ignition, remove the 6 screws underneath the steering column holding the plastic covers. Removed the covers and sprayed contact cleaner onto the mechanism next to the stem. Put a rag underneath so the fluid does not stain your carpet and let the fluid to evaporate for a while (15 minutes?) so no flamable liquid is around when you turn on the ignition This improved the situation but did not completely eliminate it. But good enough for me. Bottle of contact cleaner costs AU$25 so its a relatively costly fix but I'll use the can for other projects in the future.
red73mustang
Oct 21, 2007 12:43 PM
Cjsredpra
Jul 25, 2007 01:00 AM
johnseymour
Jul 10, 2007 02:33 AM
cedric
Apr 13, 2007 02:12 AM
thill2708
Apr 12, 2006 07:48 PM
