92 Camry Transmission Woes
Old Apr 16, 2008 | 02:38 PM
BCCamry92's Avatar
Default 92 Camry Transmission Woes
My daughter's 92 Camry's (4 cyl, auto) auto transmission just failed at 234,000 kms (145,000 miles). I'm told only used transmissions from a 92 & 93 will work. I've located a 95 parts Camry with a 4 cyl & automatic.
Does anyone know what's involved in using the 95 tranny in a 92.
Old Apr 16, 2008 | 03:50 PM
Default RE: 92 Camry Transmission Woes
The Generation 3 Camry ran from 1992-1996. 2.0L and 2.2L 4 cylinder engines were used in the 1992 and then only the 2.2L in the 1995. All used the A140E transmission.
Both trans used for the 2.2L use the same internal parts, axles, flex plate but somehow the engine starter appears differant. Might be just an upgrade.
Should be OK IF both engines are the 2.2L and the trans is a A140E (not a A140L or A140H). Not sure about the 2.0L which also used this trans but some of the parts seem differant.
You can tell the engine type by looking at the intake manifold, if 2.2L should read 2200. If the smaller engine may display 2000 but not sure. The trans number A140E should be printed on a sticker, edge of drivers door along with other numbers.
If going this route might grab the starter (and bolts), flex plate ( and crank bolts), then clip off any going wires to the trans before the plug just in case the plugs are differant between trans.
Not 100% sure but it looks OK, perhaps other members can post in.
What reason were you given for using only the 92/93?
Old Apr 16, 2008 | 04:15 PM
BCCamry92's Avatar
Our car has the 2.2 engine. I was told by the repair shop that 92-93 were compatable and 94 & up were different, different electronics.
Old Apr 16, 2008 | 07:57 PM
I can check the wiring diagrams for both years and see what the differance is.
Old Apr 16, 2008 | 09:09 PM
BCCamry92's Avatar
I did some more checking and the 4 cyl auto trans for 92 - 93 is shaped differently to the one for 94 & up. They aren't interchangable.
Fixitvich
Mar 22, 2015 02:14 PM
skszooman
Oct 11, 2010 10:27 PM
skszooman
Oct 11, 2010 09:20 PM
lpearson
Jul 8, 2006 04:24 PM
TOTALXTC
Apr 10, 2006 10:36 PM
